  New Posts New Posts RSS Feed - what tops sound best over 186
CritikalMass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CritikalMass Quote  Post ReplyReply Direct Link To This Post Topic: what tops sound best over 186
    Posted: 05 August 2013 at 11:04pm
Just curious on opinions, thinking of upgrading. We play heavy bass and need loud crisp tops that cross nicley with our es18bph cabs.
At the moment we cross subs 35-80 kicks 80-200 and pick the rest up with full range pa speakers. Cheers for all and any input.
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2013 at 11:11pm
How many tops are you planning on running each side?
MT122 are great but have very narrow dispersion so you would need atleast 2-3 a side to give a wider dispersion.
mt130 also a very popular design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CritikalMass Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2013 at 11:15pm
Thanks, we plan for two per side initially and then get another two later. Can you Reccomend anything like this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CritikalMass Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2013 at 11:18pm
Sorry I mean is there any other designs that would work? Maybe single 15 + 2" comp really want to keep down to single amp and want to be able to daisy chain two per channel on the amp
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2013 at 5:19am
You won't need a 15 inch top if you are running then from 180-200 up. You could look into some X12 style 12"+1" or 2x12" + 1" reflex tops with passive x-overs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CritikalMass Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2013 at 3:34pm
Ok, have looked at x12 and 2x12 +1 cabs and was wondering if a similer design could be applicable to a 2x8 + 1" with a mid horn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CritikalMass Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2013 at 3:35pm
The two 8" drivers mounted in mid horns would be better with high freq mounted in front.a 10" MT kinda design.
Edited by CritikalMass - 06 August 2013 at 3:37pm
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 27 August 2013 at 11:23am
Im going to be going down doobers route tops wise with our 186bins 40-125hz (ish may adjust wen measurements are taken) will need 2or more amps tho 10"reflex tuned to 80ish shud work
insert silly sentence here
