  New Posts New Posts RSS Feed - which is better overall
wickedweb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wickedweb Quote  Post ReplyReply Direct Link To This Post Topic: which is better overall
    Posted: 18 July 2007 at 2:47pm
how's it going. i'm new to all this speaker lark and i was just wondering whats the better speaker box the 1850 or the 186 horn.
adambomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adambomb Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2007 at 3:00pm
Depends which driver you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wickedweb Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2007 at 3:02pm
the pd1850
biotec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote biotec Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2007 at 3:16pm
then the 1850 cab is better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wickedweb Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2007 at 5:08pm
if i dont us a pd1850 what drivers would you recomend for both
Post Options Post Options   Thanks (0) Thanks(0)   Quote adambomb Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2007 at 5:23pm
The 1850 horn is designed for the PD1850 driver.
The 186 horn is designed for the PD186 driver.
Out of the 2, I think I'm correct in saying, you will find more compatible drivers for the 186 horn.
Edited by adambomb - 18 July 2007 at 5:23pm
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2007 at 9:07pm
basicaly the pd1850 and v-18 [only v-18 1000 ]
go in 1850 horns, pd186 and the other listed alternatives on the plans go into the 186 horn, in short the 1850 horn when equiped with suitable driver is louder and harder, and less musical sounding [so brute force] and the 186 is slightly lesss loud and more musical sounding, using the correct drivers is paramount here though so only use what is mentioned in the plans unless you know what you are doing, or itl cost you a bomb when you blow 4 drivers irrepairably when they only cost 20% less than the suggested drivers which wouldnt have died....
horn loaded for her pleasure
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2007 at 9:21pm
Are you after deep sub bass or just punchy kick bass?
How many cabs do you intend to use?
I don't believe you are gonna get much  sub from 1850 horns unless you
have at least 4 cabs.
Which isnt cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wickedweb Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2007 at 10:20pm
im not sure what sort of bass im looking for,well im thinking of having atleast 4-5 cabs.mostly breakbeat,hard trance,hardstyle,speed garage an other free party music will be played though them.still havent decided what mids an tops to get.was thinking some hd15's for the mids,dont no about tops
Edited by wickedweb - 19 July 2007 at 6:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote adambomb Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2007 at 7:23pm
Start again... what are your requirments..
Audience / Venue size.
Budget
I don't think HD15s and 1850 / 186 Horns are a good combo to work together (they cover a similer band)...
HD15s should be used in 2 way bass setups with real subs, X1s, Labs etc... They are a kick bass cab, not a mid cab.
1850 / 186 Horns should be used used in LARGE piles (4 per side or more) for 1 way bass setups.
Although they stick kick it out at impressive levels in smaller stacks, they will not go that low in small numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote adambomb Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2007 at 7:24pm
You should also bare in mind the PD1850 is around £250.. if you can find one, the PD186 about £140.
Check out Heathrows Ebay auction.. 4 PD1850s!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wickedweb Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2007 at 8:57pm
well money is no object so wat sort of speakers would you say to build for a phat free party stack.i want phat kick and deep bass?a bit of both cause there will be all different type of music goin through it
Edited by wickedweb - 21 July 2007 at 11:06am
