  New Posts New Posts RSS Feed - William Cowan's Horn
dj-panoramix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Topic: William Cowan's Horn
    Posted: 18 September 2009 at 12:43am
i just found an interesting horn on his websites, it's look like it had been designed for a dual 10inch driver, and he make a modification for a single 15" fane driver, fane 15xb:
here is the plan but remember that the plan is for the dual 10" driver and the closed part must be bigger for using with the fane driver(have a look to the link i post on the end of this thread, the guy gives some explanation about the modification), you have to get about 60L VRC:
here is a simulation with the fane 15XB vs wsx with 18P300,the 2box in 0,5PI(i used the input parameter from his website, so you have to check if good):
black is fane, grey is wsx
here are the hornresp input parameter(i didn't chek them):
here's the link from the designer, with some explanations about the modification and original design:
Edited by dj-panoramix - 18 September 2009 at 12:51am
Centauri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Centauri Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2009 at 1:25am
There are a couple of errors in this simulation....
First, the second conical section is not 84cm long and should be more like 50.
Secondly, The fourth section of flare in the sim needs to be removed completely - you CANNOT try to include the walls/floor as a horn section AND model eighth space as well, its one or the other.  William has been chipped on this many times before...
The size of the room the sub is used in will introduce "cabin gain" at the low end, and the amount will depend entirely on the room - a measured increase in low end compared to the sims with the box in position has nothing to do with any increased performance of the box, but everything to do with the room it is in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2009 at 12:40pm
ok as i said before i didn't check it(thanks for doing it), here's a simulation with last section removed and 2nd con value to 50:
grey wsx, black fane15XB
Edited by dj-panoramix - 18 September 2009 at 12:59pm
kiriiz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kiriiz Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2009 at 12:45pm
Originally posted by dj-panoramix dj-panoramix wrote:
ok as i said before i didn't check it, here's a simulation with last section removed and 2nd con value to 50:
Shocked
so flat!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2009 at 1:10pm
yes really flat, i'm just trying to play with hornresp to get a little beat more lowend, but i'm really not an expert so maybe it will not be better after... LOL
anybody know a good cad program but freeware ?
Edited by dj-panoramix - 18 September 2009 at 1:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kiriiz Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2009 at 5:12pm
700x600x560 can fit in my car... Ermm interesting...
How classic horns sounds in such a small space?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2009 at 7:24pm
never try a horn in a car so can't tell, but in little space horn are not the best sounding...in car my favourit is closed box for sound quality, and vented when you need some extra db.
KenTech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenTech Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2009 at 10:30pm
had anybody tried this Horn ? will it sound better if i put a 18" there? ofcourse, rissing the cab with a few cm.. like 15 cm maybe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2009 at 2:05pm
to know if it will sound better, you have to try...
on simulation i get similar results with a 18woofer with modification of the S's values, but that will do the box much bigger for the same result, not interesting at all.
and when i used a 18woofer with same parameter it give big dip and peak:
JDCutta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDCutta Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2010 at 4:43am
Has anyone built the 15'' version of this? Any way  of modifying the design to get it playing lower, does any one know what the spl would be in open space?
matteom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matteom Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2010 at 11:43am
my horn:
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDCutta Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2010 at 12:07am
any more details on your horn mate?
