Wireless uplighters |
Page <12 |
| Author | ||
djgorey
Joined: 29 December 2007 Location: S. Wales Status: Offline Points: 1311 |
Posted: 15 May 2019 at 12:12am |
Cool thanks.
Gaffa tape is like the force in Star Wars - there's a dark side and a light side and it holds the universe together
JonB67
Joined: 22 April 2016 Location: UK Status: Offline Points: 1352 |
Posted: 15 May 2019 at 12:14pm |
Not sure that's what he meant? I think he means 7x 5w rgb cobs vs 1x35w rgb cob (which will be much of a muchness) rather than seperate red green and blue leds, which as you say look rubbish if used close enough to anything to see the colour seperation. Most will give the actual lumen output if you dig through the spec sheet although how accurate that is for comparison purposes is anyone's guess. I disagree that you won't notice colour chases and changes. We stick 10 pars out in a large village hall and totally change the room colour and feel. Ability to use this to good effect totally depends on ambient light conditions. Djgorey if you pm me I'll send you some videos directly.
djgorey
Posted: 15 May 2019 at 1:22pm |
Looking at the transceiver side - are they proprietary? i.e. Will a Chauvet transceiver work with a Prolights Smartbat? They all look to be working on the 2.4GHz band, but I understand there's different channels within that band.
kedwardsleisure
Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 5157 |
Posted: 06 September 2019 at 10:17pm |
A client of mine has a load of these. Nice & bright and will do 2 gigs in between charges. Had 2 failures, one with a dud LCD screen and the other with a failed battery pack, parts all supplied free by 7C.
He says the big issue with wireless is the kids tend to pick them up and play with them 7c lighting Edited by kedwardsleisure - 06 September 2019 at 10:17pm |
North Staffordshire |
djgorey
Posted: 07 September 2019 at 8:10am |
I’ve got 8 chauvet freedom sticks and the kids are fine; it’s the adults that want to play light sabres with them that’s the problem
djgorey
Posted: 07 September 2019 at 11:37pm |
And tonight a new one - women using them as a ... substitute
kedwardsleisure
Posted: 15 September 2019 at 11:27pm |
you must have a better class of guest. I've had reports here of children getting confused with floor-standing moving heads and trying to ride them like one of those bucking broncos.
Page <12 |
