would 18sound 12mb700 work? |
C-Audiofreak
Joined: 12 June 2014 Location: Norfolk uk Status: Offline Points: 467 |
Topic: would 18sound 12mb700 work?Posted: 19 October 2014 at 8:08pm |
hi guys when i build these cabs i'm thinking of using 18sound 12mb 700 as the suggested units would these be any good as the spec on the website states its ideal for horn loading and it will go in a small enclosure from 10-80 ltr's and i made the enclosure for the 12's in this cab approx 19l these units are also very high efficiency so if i start by building one pair of these to go with one pair of x1 and one pair of es18 bph kicks i will then know if i will need to build a second pair of everything.
Also how many folk would this rig cater for outside? ie 4, X1 4 ,ES18 4, MT122 if set up and driven correctly? |
cravings
Joined: 30 January 2007 Location: Ireland Status: Online Points: 7508 |
Posted: 19 October 2014 at 8:58pm |
http://www.speakerplans.com/index.php?id=faq10
there's some good info in the faq. this one may also be of interest to you. http://www.speakerplans.com/index.php?id=faq3 |
Mark James
Joined: 15 January 2006 Location: rig side Status: Offline Points: 5306 |
Posted: 23 October 2014 at 9:37pm |
im pretty sure you want alot less than 19 litres for the rear chamber on the mt122 horn, pretty sure less than 1 litre is ideal [the suggestion of 10-80 litres is usualy for a reflex cab] il have a look at the t/s tho, if they are within say 10% differences from the pd123er or other known good drivers in this cab then it wil PROBABLY work as well
insert silly sentence here
