  New Posts New Posts RSS Feed - WSX driver on the budget
arxxx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arxxx Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2009 at 6:47am
will RCF S800 work in WSX
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2009 at 5:44pm
Originally posted by Mircea Bartic Mircea Bartic wrote:
look for the C18ELF the replacement for C18-650EL
it has double spider
Pro Audio PArts show the 650EL as double spider. Is it not?
 Ta
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2009 at 6:00pm
i just reconed one and cant remember, think it was though......
yeah i think it was? but thats an 80% sureness factor
insert silly sentence here
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2009 at 6:55pm
Single spider
Edited by Mircea Bartic - 21 March 2009 at 6:56pm
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2009 at 7:14pm
as I said I could well be wrong, and I stand corrected!
M
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2009 at 9:19pm
PAP need to change that then! I nearly bought some of those, close call. Thanks MB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2009 at 9:58pm
just to check i will look at a recone kit when i get in monday if this is incorect I will get onto someone about changing it.
many appologies if that is the case on behalf of pap.
I can only assume that this originated from inacurate info from p-audio, although I cant say for sure as I wasnt there at the time.
M
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2009 at 10:44pm
That's quite funny, I forgot you were with PAP, nothing personalSmile
P Audio's site doesn't actually help, no info on single or dual..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2009 at 1:28am
as i said i will physicaly double check a kit on monday but i would go with mercia hes probably seen as many as me if not mroe lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2009 at 7:32am
The new C18ELF does have double spider now
Ex Nexus_3
malina View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote malina Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2009 at 9:14am
Can anyone simulate WSX LF18G401 loaded in HR and confirm will it work better than the original L18P300 or not because of G401 thiele being much better suited for horn loading then P300.
Comments please.
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2009 at 10:01am
try to learn HR, it's pretty simple check database simulation thread in otherplans section, there are many examples.
