  New Posts New Posts RSS Feed - X-12 style DJ Monitors?
Sequence Empire:::.. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sequence Empire:::.. Quote  Post ReplyReply Direct Link To This Post Topic: X-12 style DJ Monitors?
    Posted: 04 May 2009 at 4:22am
Things are progressing rather quickly with the MT121/1850 Builds I'm doing so I have to start looking at good monitors for the DJ Booth.
Am I correct thinking the X-12's are more of a FOH/Mid-tops of a stack design? Or can these be used for DJ Booth?
Can anyone recommend a really nice 2 x 12"+HF, X-12 style DJ monitor free plans?
Some of the best outdoor Rigs I have DJ'd on have had floor standing dual 12"+ HF
Clear, Clean Loud be the qualities I am after.
Jim
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2009 at 9:13am
If you were using it for a DJ monitor I would recommend building an X12 with the HF between the two 12" drivers.  It would make a very loud monitor!
Just modify the design to suit your needs.  The cabinet shape isn't critical.  As long as you end up with a sensible internal volume and tune it in the right region you'll be fine.  There's a massive selection of drivers which will work in it too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sequence Empire:::.. Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2009 at 9:24am
Nice, cheers Ceharden,
Will fire up AutoCAD & see how they might look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2009 at 10:32am
You might want to find a wider dispersion horn for monitor use too.  If you choose some 12" drivers with a bit more low extension you can turn the box into more of a full range cab.
H... View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H... Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2009 at 11:49am
Often though about this - something like
2 x P-audio SERIES 2 SN12MB
1 x P-audio SERIES 2 BMD 740 1.4"
1 x P-audio PH 85
run bi amp
in a MTM style cab - it should belt it out, make a nexo PS 5 sided trap style box and a handy full range box too.
Don't worry F$cked up bigger gigs than this one...........
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2009 at 1:24pm
The SN12mb seems to be pretty hard to find at the moment, have a look at the Celestion 12" TN as an alternative. I have just used a couple and have been very impressed for the money. Since I built them for a client I have 2 more orders after pepes just had a listen!!!!
The nice thing is they are pretty smooth up to 4k which makes x-over design and comp choice much easier.
As Chris stated just use a 1" comp between the 2 bass/mid drivers. Cross as low as possible but you could push it up to about 2.5K with just a little beaming from the 12" ers.
With the Celestions it should do about 128db cont. which is enough even for deaf DJ types.
Tony
Edited by Tony Wilkes - 04 May 2009 at 1:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2009 at 1:30pm
I would stick with a large format compression drivers as per H's suggestion.  If nothing else they're harder to kill!  Crossover point about 1.5kHz.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2009 at 2:53pm
That's because you do not use the proper 1" ers. Wink
Tony
H... View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H... Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2009 at 3:28pm
@ Tony Wilkes
1 x P-audio PH 85
run bi amp
SERIES 2
Plenty of 'em in the mother land!
Edited by H... - 04 May 2009 at 3:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2009 at 6:44pm
@H
When I was after some SN12mb's a few weeks ago could not find any in the UK, the only half respectable budget Neo driver I could find was the Celestion, glad I did it proved to be a cheap little gem.
It has not got the absolute definition of some of the European products though I would say it was a match for the MKI SN series.
Tony
breakdabeat pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote breakdabeat pete Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2009 at 6:49pm
which celestion tn was it tony??
specs look pretty good on the TN1230
Edited by breakdabeat pete - 04 May 2009 at 6:50pm
٩(̾●̮̮̃̾•̃̾)۶
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2009 at 6:55pm
It was the TN1225. Its smaller voice coil gives it a smoother top end. Its only 50w less power handling but looking at the graphs it seems to make up for this with  greater efficiency.
Tony
