x12 / x15 with Eminence and Selenium |
skejack
Topic: x12 / x15 with Eminence and SeleniumPosted: 24 May 2010 at 9:07pm |
Hi, i'm from Uruguay, and I'm trying to design a PA system for live sound...
Now, I can't to get a PAudio components, and I thought of using the speaker: Eminece Kappa Pro 12a and the driver: Selenium 3305 TI... Eminence specs: http://www.eminence.com/pdf/kappapro-12a.pdf Selenium specs: http://www.selenium.com.br/#/Produtos?c=1&m=0&f=0&l=13&r=0.1212192764505744 Another possibility is to use two x15 cabinets instead of one x12 per side with Eminence Kappa Pro 15a, and the same driver... Do you think? Which option will have better results? Have you a suggested design for my components? (everything is for mid/high range) Thanks! |
skejack
Posted: 24 May 2010 at 9:10pm |
I forgot!
In the Eminence's website have a cabinet design for a Kappa 12a, but, i can't understand this information.. This is here: http://www.eminence.com/pdf/cab-kappapro-12a.pdf |
