  New Posts New Posts RSS Feed - X15 Braces/Dotted Lines/Wadding
reessi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reessi Quote  Post ReplyReply Direct Link To This Post Topic: X15 Braces/Dotted Lines/Wadding
    Posted: 23 September 2013 at 6:57pm
Hi, I would like to clarify a few things,
First of all do I need to put wadding in these speakers and if so would I just cover the back of the speaker inside?
Second is on the diagram it has dotted lines twice half way down the front and showing on the side view, are these braces? One looks like it may support the horn inside but what is the next one down for which appears to be part way across the bass speaker but further back?
Many thanks.
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2013 at 7:50pm
Some wadding in the back of the cabinet would probably be useful, yes.
The dotted lines are pieces of timber mounted across the cabinet to stiffen it and prevent the panels flexing - the upper one runs from the front to the back and the lower one from side to side.
HTH,
David.
Post Options Post Options   Thanks (0) Thanks(0)   Quote reessi Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2013 at 9:12pm
Hi thanks mate,
This is what I thought was the case,
Cheers.
