XM15 mitre angles |
datguyjoe
Registered User Joined: 20 January 2005 Location: UK Status: Offline Points: 19 |
Posted: 02 November 2007 at 3:56am |
'ello,
I'm about to make an XM15 and was wondering if someone knows what the angles are for the mitred cuts. I would assume 45 degrees? Thanks. |
Richard Hart
Young Croc Joined: 08 November 2005 Location: Leeds Status: Offline Points: 637 |
Yes, 45 degrees. In the 90 degree plane there are two equal angles, just half it to get the individual value.
kevin tyler
Old Croc Joined: 15 April 2007 Location: Spain Status: Offline Points: 3402 |
err no, not 45 degs, mark it out and measure it,
we covered this when i made a pair, i think the angle was not possible using a circular hand saw too.
ok if you have nice tools.
kev
edit
i cant find the post, but i remember we had a discussion on here regarding making a jig to pass the pieces through a vertical blade to obtain the right angle??
edit
here it is
Edited by kevin tyler - 20 November 2007 at 9:58am |
Richard Hart
Kevin you are totally right, schoolboy error!
Just worked it out with trig, ones 39 and the other's 51.
ceharden
You could adjust the cab to have 45deg angles if you wanted tho.... Wouldn't make a lot of difference other than the angle it sits at on the floor.
Also, you don't need to cut a 51deg angle, just cut a 25.5deg mitre on each of the pieces instead! |
