XM15 mitre angles |
datguyjoe
Joined: 20 January 2005 Location: UK Status: Offline Points: 19 |
Topic: XM15 mitre anglesPosted: 02 November 2007 at 3:56am |
'ello,
I'm about to make an XM15 and was wondering if someone knows what the angles are for the mitred cuts. I would assume 45 degrees? Thanks. |
Richard Hart
Joined: 08 November 2005 Location: Leeds Status: Offline Points: 643 |
Posted: 03 November 2007 at 10:21am |
Yes, 45 degrees. In the 90 degree plane there are two equal angles, just half it to get the individual value.
kevin tyler
Joined: 15 April 2007 Location: Spain Status: Offline Points: 3408 |
Posted: 20 November 2007 at 9:41am |
err no, not 45 degs, mark it out and measure it,
we covered this when i made a pair, i think the angle was not possible using a circular hand saw too.
ok if you have nice tools.
kev
edit
i cant find the post, but i remember we had a discussion on here regarding making a jig to pass the pieces through a vertical blade to obtain the right angle??
edit
here it is
Edited by kevin tyler - 20 November 2007 at 9:58am |
Richard Hart
Posted: 25 November 2007 at 4:04pm |
Kevin you are totally right, schoolboy error!
Just worked it out with trig, ones 39 and the other's 51.
ceharden
Posted: 26 November 2007 at 12:43am |
You could adjust the cab to have 45deg angles if you wanted tho.... Wouldn't make a lot of difference other than the angle it sits at on the floor.
Also, you don't need to cut a 51deg angle, just cut a 25.5deg mitre on each of the pieces instead! |
