XP running slow? |
Page <1 234 |
mini-mad ![]() Old Croc ![]() ![]() Joined: 13 July 2012 Location: london Status: Offline Points: 6903 |
Oprera sucks..... sorry. IE11 is, well.... IE!! If you just turn off all the bells and wistles off on chrome and just run ad block pro it works beautifully.
firefox still has its advantages... speed not being one of them. i use seamonkey within DSL and thats pretty sweet for crusingnthe net. but for out and out speed in XP remove all the stupid games you download to pass time.... clean out the reg. And cut all the shite out of the startup programmes via msconfig. |
jazomir ![]() Old Croc ![]() Joined: 20 November 2006 Location: Sunderland UK Status: Offline Points: 1694 |
I started having the same problem again this evening - tried your tip and it worked first time! Brilliant bit of advice - thanks! Now all I have to do is figure out what is causing the DNS problems. Simples.
shagnasty ![]() Old Croc ![]() Joined: 30 July 2007 Location: Guildford, UK Status: Offline Points: 7685 |
write a little batch that file that runs from startup to flushdns everytime you powerup?
amlu ![]() Young Croc ![]() ![]() Joined: 30 November 2009 Location: london Status: Offline Points: 740 |
processhacker.sourceforge.net/
or some other good task manager that will show you what is eating up your cpu. there was a windows update bug a while ago with associated svchost chewing up 100% cpu... flash player and hd video play is not easy on older systems too. |
Loaded it and looks good - thanks for the tip.
That was the one that caused the initial problem - Windows 7 code put inside an XP update made worse by the fact the code was for Windows updater, so couldn't easily be fixed (there was a fix developed for it just before Xmas - just before MS got their act together). The trouble was the problem showed itself in different ways on each machine - caused no end of heartache for system administrators.
Can't believe it - machine working nicely, then on Tuesday more MS updates installed and the same problem recurrs, only this time I was unable to even stop, start or even access the Windows firewall. After finding a helpful fix on the MS site I finally managed to sort out the problem. Definitely going to stop automatic updates from now on! I will post details of the fix if anyone else has the problem.
odc04r ![]() Old Croc ![]() ![]() Joined: 12 July 2006 Location: Sarfampton Status: Offline Points: 5483 |
And the good news (sort of) is that XP support has now been extended to 2015! So if you're lucky you can have another year of this. Hehe.
mk2_ginger_biscuit69 ![]() Old Croc ![]() Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7801 |
well i still can't get mine to download any updates, so instead i tried to run the Eee pc bootdisk to fresh install windows off of a USB DVD drive - and it won't recognise the drive [which works fine on my win7 machine].
in short - my laptop is fecked and i cannot do anything to bodge it!! So bloody annoying...... |
Sinai Sound ![]() Young Croc ![]() ![]() Joined: 09 November 2009 Location: Sheffield Status: Offline Points: 623 |
XP support hasn't been extended to 2015, they have in fact extended the amount of time they will continue to supply updates for their anti-malware software
Windows updates will stop as of April 8 2014 If anyone is still having problems with high cpu usage, try installing this http://support.microsoft.com/kb/2898785 Then running windows update I installed a fresh copy of windows XP the other day and had to install the above update to get windows updates to work Edited by Sinai Sound - 17 January 2014 at 2:54pm |
or removing the harddrive.... stick it in a working oc load the drive with xp and rite at the biggining of the install it loads the basic files needed to get it to startmloadimg windows itself.... just as it goes for its 1st reboot, whip it out, plug it back into the laptop, hook up the usb drive with the install disk and take it from the. iv had a 70-80% hit rate doing this. |
You're not wrong, that'll teach me to skim read stuff. |
Page <1 234 |
