  New Posts New Posts RSS Feed - Yet another MT121 Build
Sequence Empire:::.. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sequence Empire:::.. Quote  Post ReplyReply Direct Link To This Post Topic: Yet another MT121 Build
    Posted: 31 March 2009 at 10:50pm
Just about to start with the cutting on my companies Laser Cutter all the parts to make two MT121 Cabs loaded with P-Audio SN12B and Beyma cp750Nd's/TD460n horns
Plans drawn up with my idea on the MF Horizontal Flare
Will post some photo's up as the parts get cut, also have a custom grill panels coming from our Finn Power Turret Punch where I work, 2500 hits with a dia 8.2mm punch done in around 8mins Tongue
Open to discussion on the curved section for the flare. I intend to form and laminate 3 layers of 4mm ply over some formers, idea derived from the speakerplans readers project HD15 curve lamination photos.
Wish me luck!
These will be going above Lab subs and Usb's
Edited by Sequence Empire:::.. - 31 March 2009 at 10:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sequence Empire:::.. Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2009 at 1:30am
Big smile
Parts all CNC Router cut last night, I'll be posting up some photo's of them when I get home from work, cannae wait to start building!
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sequence Empire:::.. Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2009 at 10:28am
Right, heres a few quick shots of the router cutting & quick mock-up of the cab & showing off the grill
Get the table saw up & going this weekend to get bevels done then start dry fitting parts
tbc
Jim
H... View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H... Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2009 at 12:29pm
Lovely grill work there fella!
Don't worry F$cked up bigger gigs than this one...........
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2009 at 12:50pm
yeah really nice there.
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2009 at 7:55pm
very good work
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sequence Empire:::.. Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2009 at 9:09pm
Originally posted by TDA-Audio TDA-Audio wrote:
very good work
Inspired by your MT121 pics good sir!
shadow1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shadow1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2009 at 10:21pm
Those grills are wicked.... I could do with some grills like those, wink wink !
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2009 at 10:23pm
CNC cut wood will give you a brilliant finish!!
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2009 at 10:54pm
Flex, bling, brap, and any other of the yoot'dem term to describe extreme goodness. Wish mine looked as good! Grille like that is about £50 a sheet in bnq
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sequence Empire:::.. Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2009 at 1:26am
Top & bottom panels pre-drilled last night, 12mm ply plant ons glued in place, SN-12B's on their way to my door...
Jig to form the horizontal dispersion parts of the mid freq flare constructed, see how the Lamination goes...
Cheers to all for the positive words
first build of this scale, happy I've invested in quality ply & cnc router cutting this far
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sequence Empire:::.. Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2009 at 1:41am
Try a sheet-metal engineering shop in your local area if you want a custom design.
Someone proficient with AutoCAD can draw up the profile for you, my grills were manufactured on a Turret Punch where I work. If you find a company with a Turret Punch & do a little research as to what tooling is available there, as working with what they have available will see the initial design go through to produce a really good end result. The holes in my design are 8.2mm dia, on 12mm circular pitch centre.
Edited by Sequence Empire:::.. - 01 May 2009 at 1:44am
