| Author |
Topic Search Topic Options
levyte357
Topic: Yorkville AP6040 amps for sub Posted: 27 November 2007 at 2:52pm |
Anyone in UK used these. Heard conflicting stories, but many people like them
Yorkville: AP AP6040 - Amplifier - 2x 2000w @ 4 Ohms
Specifications
| Amplifier class | H |
| Continuous Average Power @ 8 Ohms BCD (Watts) | 1250 (x2) |
| Continuous Average Power @ 4 Ohms BCD (Watts) | 2000 (x2) |
| Continuous Average Power @ 2 Ohms BCD (Watts) | NA |
| Continuous Average Power Bridged BCD (Watts) | NA |
| Burst Average Power @ 8 Ohms BCD (Watts) | 2000 (x2) |
| Burst Average Power @ 4 Ohms BCD (Watts) | 3625 (x2) |
| Burst Average Power @ 2 Ohms BCD (Watts) | NA |
| Burst Average Power Bridged BCD (Watts) | NA |
| Frequency Response (Hz, +/- 1dB) | 20-20,000 |
| Hum and Noise (un / Aweighted -dB) | -103 / -106 |
| THD -1kHz- 4 OHMS | 0.01% |
| THD - 20Hz-20kHz, 4 Ohms | less than 0.1% |
| Slew Rate (V/uS) | 50 |
| Damping Factor (30 Hz - 400 Hz @ 8 Ohms) | 600 |
| Crosstalk (1kHz / 20Hz-20kHz) | -75 / -60 dB |
| Input Impedance - Bal/Unbal (Ohms) | 20,000/10,000 |
| Input Sensitivity (Vrms) For Full Power Out | 1.4 V |
| Max Voltage Gain (dB) | 41 |
| CMRR @ 60Hz (min/typ) | 48/56 dB |
| Stereo / Mono / Bridge (S/M/B) | S/M |
| Protection | DC,Load,Thermal |
| Limiter | Peak |
| High Pass Filter | 40Hz, 12dB Octave |
| Cooling | Dual Internal Fans |
| Cooling Path | Front to Rear |
| Fan Filter | 2x User Serviceable |
| Inputs - XLR | 2 |
| Inputs - 1/4" Jacks | 2 |
| Outputs - Speakon 4-pin | 2 |
| Outputs - Binding Post | 2 |
| Power Consumption (typ/max) | 1800/3000 Watts |
| Rack Spaces | 3 |
| Transformer Type | Toroidal |
| Exterior Finish | Baked, Black Painted |
| Dimensions (DWH /D fm ears, inches) | 19 x 18.5 x 25 x 17.6 |
| Dimensions (DWH /D fm ears, cm) | 48.3 x 47 x 13.3 x 44.7 |
| Weight (lbs / kg) | 66.1 / 30 |
tweeter box
Posted: 27 November 2007 at 5:57pm |
Looks like they cant be bridged???
doober
Posted: 27 November 2007 at 6:18pm |
Do you know of anywhere in the UK that sells them? Last time I looked I couldn't find any Yorkville dealers.
Blahblahblah
shagnasty
Posted: 27 November 2007 at 9:08pm |
No 2 ohm drive so if it did bridge (you could try with a phase changer) it would only drive 8ohm in bridge anyway...
May use dual bridged modules to get that kinda power outta 30Kgs anyway!!!
(probably best to check with ameter BEFORE you try the pahse changer trick!!!)
Jhodas
Posted: 27 November 2007 at 10:09pm |
I can't get to their website...
levyte357
Posted: 28 November 2007 at 12:32am |
tweeter box wrote:
Looks like they cant be bridged??? |
Why would you want to bridge this ? It can do 2kwpc@ 4ohms, thats 2x 8ohm 18's per channel @ approx 1kw each. Job done.
Tekasis
Posted: 26 July 2008 at 8:03pm |
levyte357 wrote:
Anyone in UK used these. |
Only found one user on here who rates them!.
davidcordingley wrote:
if your in the states look at yorkville ap6040 these go quite well i have six of them and don,t need anymore power than that.four rows of eight to3s per channel.32 kilos.proper job...thats right 32 moses per channel.tidy.. |
Any more ?
doober wrote:
Do you know of anywhere in the UK that sells them? Last time I looked I couldn't find any Yorkville dealers. |
Jhodas wrote:
I can't get to their website... |
Check out their service manual...
Don't seem like many manufactures supply this type of detailed info!!!
Edited by Tekasis - 26 July 2008 at 8:04pm
**Heavy Weight-Line**
sKs01
Posted: 26 July 2008 at 8:19pm |
people seem to nod their head towards yorkville in general on psw for this sort of aplication, as above i didnt know their were any uk dealers?
doober
Posted: 27 July 2008 at 8:57pm |
I emailed the uk distributor http://mirep.co.uk/to try and get a price and try a demo unit, but never got a reply.
I take Dave Cordingly's opinion highly, I used to do parties with him years ago, he was never happy with the bass until eyeballs were wobbling and people were struggling to breathe.
Blahblahblah
powerplant
Posted: 08 March 2012 at 7:22am |
Hello guys , looks like I am about to burst yorkville bag, the Ap 6040 is no miracle amp , just like crest 8001, qsc mx3000a , or EV p3000 operating at 2 ohm (also the ap 6020).
That is, 1400 watts, - 1600 watts , depending on either 20 - 20 hz @ 0.05 thd rating or 1 khz @ 1% thd Rating. All the amps are of the same class weighing in at 67 pounds same topology , Only way AP6040 can achieve the claimed 2000 watts of clean power is by driving only one channel at 4 ohms. These 4 ohm limit amps just run out of breath ( headroom) . The ap 6040 may sound just like the RMX 5050 or worst @ 4 ohms. bink's amp shoot out results were accurate. 1400 watts a 20 hz . just like crest 8001 2 ohm specs and 1700 watts @ 1 khz just like qsc mx3000 . therefore at clean real world power the ap 6040 is more like 1700 watts both channels driven , ( 3400 watts amp) . Ap 4040 follows the similar situation. Is similar to crown 2400 , and crest ca 9 . 2000 watts total real world clean power. Also AP 3400 . AB Test sounded same .
levyte357
Posted: 08 March 2012 at 9:34am |
powerplant wrote:
Hello guys , looks like I am about to burst yorkville bag, |
Since start of this thread, many amps have become available in UK that would smoke the Yorkville, @ 4 ohms stereo. Was told years ago they are a nightmare to service/repair, lost interest there and then.
MessyM2k8
Posted: 08 March 2012 at 10:12am |
S DeXter on here had one. They are a nightmare to repair.
