  New Posts New Posts RSS Feed - Yorkville AP6040 amps for sub
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2012 at 10:35am
Originally posted by MessyM2k8 MessyM2k8 wrote:
S DeXter on here had one. They are a nightmare to repair.
Yes.
http://forum.speakerplans.com/help-needed-hk-vc-2400-yorkville-ap4040_topic61762_post615343.html?KW=yorkville#615343
powerplant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powerplant Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2012 at 12:32pm
Without a doubt, the Ap series Power Amps are very reliable and durable with straight forward analog circuitry. However, here in trinidad the semiconductor market has lost its way totally in inferior chinese replacement parts  and  compounded by the nonavailability of precision specialized  parts making proper restoration  impossible.  I have one ap 6040 that i purchased broken with the inention to restore as a project but have not done so in consequence of the above . Customer support also leaves much to be desired. and finally, the general cost of yorkville amps.
To replace the two circuit boards  Yorkville charging $900 us . I can buy a used PL 6.0 ,  B stock  crest CC5500,  Peavey cs 4080 , crown ma3600 , .
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2012 at 7:53pm
Yorkville stuff built like brick toilets and very comprehensive service manuals.
In the uk they are sold under the HK Audio brand which is distributed by John Hornby Skewes.
North Staffordshire
C-Audiofreak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2016 at 8:46am
If the yorkville amps are only available in the uk under an HK badge how come a few yorkville badged amps crop up on the second hand market ? Are these imported by individuals? I've thought about importing a couple from the states but get them converted to 240v once here as I'm told the transformers have dual tapped transformer so the primary side to 240 instead of 110 would be a simple procedure I just want an AP6040 and another 2020 if I can get them
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2016 at 4:16pm
these come up often on European main continent.. just have a look around.. Shipping aint that bad normally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2016 at 4:22pm
Do you mean Germany etc?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2016 at 4:34pm
for example.. shipping from Germany to uk up to 45kg is only 25€..
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2016 at 4:43pm
If you do that get the fans checked, if they are DC, you are fine, but if they are AC powered, swap them, a US AC will will run slower in the UK (60Hz vs 50Hz) and may not be able to cool the amp properly...
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2016 at 11:55am
If you want to import themn you'd be better getting them from a european source as they'll be the correct voltage and there wont be a hefty import duty. I'm pretty sure they use DC variable speed fans...they're not that backward! According to Yorkville there's a trade distributor in Le Bourget France called Major Audio.
And I didnt say they were ONLY available as HK in the UK..any dealer is free to import stuff from wherever they want. My post was 5 years ago and I don't even know if HK still use Yorkville.
edit: just checked with HK and yes they still do them, called the VX series.
Edited by kedwardsleisure - 09 January 2016 at 12:01pm
North Staffordshire
70,s hero View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70,s hero Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2016 at 6:02pm
I have 4  H.K / Yorkville amps the 2400's , class A/B , quite happy with them, repaired a power supply on one, parts avaliable in U.K. Heavy old school amp
Top banana
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2016 at 6:58pm
Hi mate I wasn't questioning what you said I was just saying they are very few and far between secondhand in the uk and only ever seem to find the HK vx series of amp which are rebadged ap series yorkville amps
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2016 at 7:26pm
Those AP / VX are a bit of a tight packed amp but the quality is fantastic. Shame they arent a more popular brand here as I'm sure they'd be appreciated
North Staffordshire
