  New Posts New Posts RSS Feed - Mogale SuperScooper with PD 185c003 - question
levyte357- View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 11 October 2024 at 10:23am
If he is keeping the Super18s he built, he'll need to do homework regarding drivers that perform well in <50L Scoop chamber.
Obviously the number 1x candidate here is the Void V18-1000.
Feedback on the Forum, confirms B&C 18TBX100 also plays well in the cab, but with BL=25, and Xmax=9mm, don't expect the building shaking performance.
4x V18-1000, powered by Void Inf8mk2 amp, in Superscooper 18 cabs, tuned by right pre-amp, will provide shocking sub depth and SPL, but by nature of the cab, sub "sweet spot", will probably be about 20M distance. LOL
Edited by levyte357- - 11 October 2024 at 10:33am
DubHouse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DubHouse Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2024 at 12:33pm
Ok so i will go to pd 1852/2 as you tell me, it will be better choose.
One more question. Could i have 2 classic super scoop bins and 2 modified?
If i set it in configuration CMMC which mean (c- classic/ m - modified) it will play good ?
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2024 at 4:15pm
Originally posted by turbo7 turbo7 wrote:
Polar bear scoops do not play deeper than super scoop, as it is roughly the same design. One can find measurments of the polar bear scoop in this thread ( falling response from 50Hz down, that is pretty bad..)
Instead of wasting time and money to build the same shit again, stay with your super scoop and sacrifice 2-3dB in the low frequency range to todays top scoop/driver combos ( polar bear is NOT in the list of top scoops, at least the combo that is featured in the link above ).
sorry, have to disagree with  your claim that supers and polar bears are "the same shit"!
I don't claim to know the "top scoops", but your way of trash talking polar bears is unqualified. In the thread you linked there is not even a direct comparison  between super and polar
Polars are larger, and the internals are different. Standard supers choke and create a mushy mess below ~42 Hz, indistinguishable muddyness. I've heard Mikko's original Polars and others, and they do warm and defined 30-40 notes.
Originally posted by Sinai Sound Sinai Sound wrote:
Right then
Graphs
This is 4 x polar bear scoops measured outside
Single double 21"
The graph you based your slander on is actually not bad at all if it is half space, flat processing (except for hipass). It slopes gently down 5- 6 dB from 70 Hz to 35Hz. At 35 Hz there is a knee in the response, from there it drops another 4 dB going down to 30 Hz.
So it is 10 db down at 30 Hz. The sublows can be boosted within reason to make up for the apparent sensitivity loss, which is actually caused by increasing impedance, and less amplifier  power being dissipated in that range.
Stack of supers will be a lot worse.....
After all, how many times has it been discussed how two scoops of same external size will perform very differently, due to the chamber & throat tuning, expansiom rate etc........
I start to sound like Lev LOLLOL
Edited by bob4 - 13 October 2024 at 4:19pm
turbo7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turbo7 Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2024 at 7:48pm
Hi,
i dont slay any cabinet, all i am saying is that both designs are not more than 2dB apart, that is physics and everybody who questions that will have a hard time doing so.
There will be no complains for 4x V-18 super scoop or Polar + X, therefore i am not sure why to build double the amount of cabs, might depend on the wood prize..
Edit: The graph of the polar scoops shown in the link has a falling response from 50Hz down, that is a bad subwoofer response and is not desireable. No, one can not EQ much at 50Hz down, as it will raise powerdraw and excursion significantly.
A subwoofer response should look like the other way round as you want the energy down low not at 60Hz, just like the second graph that is shown in the link as well.
A large 18" Subwoofer should focus on the energy being in the 35Hz range not in the 60Hz range.
1600W power handling
Kind regards
Edited by turbo7 - 14 October 2024 at 7:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2024 at 9:55am
I am not suggesting PD1852 for Standard Superscooper, would suggest Void V18-1000 or B&C18TBX100 for that.
Having different Scoops/differently loaded Scoops is for novices, who don't understand the problems this causes:
  • Either sell the 2x Superscoops you have made, and make 4x of the Mykey "Scaled up Scoops", and load with PD1852s, etc.
  • Or make 2x more standard Superscooper 18s, and load them "ALL" with Voids.
That's my suggestion.
Edited by levyte357- - 14 October 2024 at 10:00am
Benelr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Benelr Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2025 at 4:41pm
Hi levyte, are you suggesting the alternative drivers in the same mogale super scooper cabinet? Pretty new to speaker design but as far as I can tell the rear loaded horn TLs dont need to be tweaked for the specific driver?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2025 at 10:09am
To obtain maximum SPL, low extension, power handling and control, sophisticated engineer, will always match driver to intended cab, by ear/testing, or shortlist intended drivers, by how well TS Parms match cab chamber, throat.
PD1850 provided legendary historical performance in its time, but put it in the wrong cab, result was mediocre, to awful.
Edited by levyte357- - 24 June 2025 at 10:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Benelr Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2025 at 11:50am
Thanks. Do you have any reccomendations on how to roughly match the SPL of 2 v18-1000 loaded super scooopers to the kicks and mids and tops of a sound system? (I know the fine tuning is done at the end)
Edited by Benelr - 26 June 2025 at 1:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2025 at 4:51pm
What I have always done, is time align using LMS, to horn length of the Scoops.
E.g., if Scoop horn length is 2M, and reflex kicks used, delay kicks by 2M.
If Mid tops has 12" front horn flare of 60cm, delay by 140cm, and similiar for the compression driver flare.
Not all will agree, but I did this for years, for many gigs, inside and out, then simply balance SPL from each section, using amplifier gains, LMS limiters per band.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Benelr Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2025 at 7:57pm
Thanks. I was more asking about how to choose the right drivers and cabinets to match the subs ive chosen.
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2025 at 8:03pm
cud be further when we used our supers sumtimes we upset the locals  bournville police on phone  sort it otherwise we will  !! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Benelr Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2025 at 9:44pm
cheers I was more asking about how to choose the right drivers (kicks, mid and top) and cabinets to match the subs ive chosen.
